How to Upgrade C-Drive from 512GB to 2 TB
Solved by Jp42nca,
38 minutes ago, IPD said:I'm at work, so I can't reference the file system here as reference. But if memory serves, the default download location (assuming you never changed any settings) is where you'd find that stuff--buried somewhere on C-drive, usually under your specific "user" account.
C drive > users> "whatever you are" > downloads
I think I know what your getting at but not sure how to find it. I'm pretty sure your not meaning my download folder, which btw has only 3.77MB total files. Maybe when you get off you can fill in the blanks. Thanks for your help-
