Shutdowns at startup, CPU lights on.
I have a theory of what happened, at my first post i mentioned that the pwm functionality of my AIO fans was not working properly and i thought it was the fans, i have the wraith prism cooler that came with my cpu and tested the pc with it, no luck. I believe that my motherboard cpu fan header fried for some reason(2A limit , 2 0.4A fans connected to it) and now the board is having trouble powering on too, some electrical issue is happening here and its not the first time i have a fried board in this setup. Im activating the RMA for the board that is clearly bad, and im talking with Corsair Support and they said i could send my PSU to them so they can properly test it and see if my psu is the bad guy, if it is they will send me a new one. I thank you guys for all the help here but i think this issue is now closed. Fried board, possible defective psu killing boards.
