So I have a XFX RX570 XXX Edition. I replayed thermal paste and now my pc case is showing a red light, and when my graphics card is under load it boosts up to 89c and max usage while making a faint buzzing sound. I checked my ram reseated my card and nothing has worked. If someone could help me that would be great!
UPDATE: My gpu caught fire 😞
UPDATE 2: IT STILL FUCKING WORKS!!!!
https://linustechtips.com/topic/1385349-i-need-help/
13 hours ago, bjorntech said:
well rip dude. a simple solution would have been secure booting. if the temps within the secure boot rose stupidly high u could have removed the new thermal paste and either tried some other past. or thermal pads.
well the thing is it wasnt getting hot it just said it was
https://linustechtips.com/topic/1385349-i-need-help/#findComment-15079147
thats weird are u sure nothing is wrong with ur cooling?
yeah the thermal spread is fine. like when i put it under load it goes up to 100% and 89c, and when i take it off load it immediately goes to 0% usage and like 36-39c. it makes a slight buzzing when under load when fans are not spinning.
https://linustechtips.com/topic/1385349-i-need-help/#findComment-15081182
