Do I need fan splitters?
3 minutes ago, zeNnG said:
I recently bougth Corsair's 4000D Airflow model and bought some 3x120 mm RGB fans too.Do i need to buy fan splitters for 4 fans.I have  a MSI z490 tomahawk motherboard.
https://www.msi.com/Motherboard/MAG-Z490-TOMAHAWK/Specification
the motherboard can fit up to 6 system fans so there's no need for a splitter
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
According to MSI, no. But still consider them if you really really want a clean build.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Which fans did you buy? If they were Corsair RGB fans, you can just get the Commander Core XT. Corsair | Amazon
Note: Do not purchase that, if they were not Corsair RGB fans, as they will ONLY WORK WITH Corsair RGB fans.
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
I had the budget to buy SP120 ones that comes with lighting node core.
https://www.hepsiburada.com/corsair-sp120-rgb-pro-120-mm-lighting-node-led-pwm-fan-triple-pack-kasa-fani-co-9050094-ww-p-HBV00000TVU64?magaza=Hepsiburada&utm_source=pc&utm_medium=akakce&utm_campaign=c&utm_content=c&utm_term=k&wt_pc=akakce.c.k.pc&v=1.77.6
1 hour ago, zeNnG said:
You should be fine with using a splitter, or better yet the commander pro instead then.
