2x 120mm fan vs 1x200mm fan
clad
I want to build my first gaming pc and i chose cm storm enforcer as my pc case....it comes with one 200mm red led front fan installed and has space for either 2x120mm fans or a single 200mm fan.....so which one should i install and why??? Also is that front red led fan removable???
Yeah all fans should be removable. You need to find the details of the fans to get the airflow per CFM etc.
I prefer a 1x200mm because it is more silent and looks cooler from the outside (both aesthetically and physically).
Laptop: METABOX W230ST | Intel i7-4700MQ | 2x4GB Dual Channel Ram | NVIDIA GTX 765M 2GB | 128GB SSD | 1TB HDD | Razer peripherals.
Desktop: Custom Desktop | Intel i5-2400 | 2x4GB Dual Channel G.Skill DDR3 | Gigabyte + XFX R9 280x CF| H61M-USB3-B3 | 1TB HDD
Larger fans don't have to spin as fast to move the same amount of air, which usually means less noise. Yes, the front 200mm fan is removeable.
Not enough information...can u tell the model number or company of which fans are...??
i have one of those 200mm fan in my case (HAF 912)
Its kind of Weird..
it moves back and fourth when it spins :D
the only sound from it is the massive amount of air
splashing in to my hard drive cage  :D
Case: HAF-912 Adv. Limited Edit. CPU: AMD FX-6300 Motherboard: Gigabyte GA-970A-DS3P RAM: Crucial DDR3 BallistiX Sport 1600MHz 8GB GPU: Sapphire Radeon R9 270X
Storage: Toshiba Desktop 1TB SATA 3.0 PSU: Corsair CX500M CPU Cooler: Noctua NH-U12P SE2 Exhaust: Noctua NF-S12A FLX
Mouse: Mad Catz RAT 7 Headphones: Steelseries Siberia V2 Orange edition Keyboard: IBM SK-8820 Monitors: Samsung S24C450 and 2 L245WP
Can u people suggest some other good pc case in the same price range
Where do you live?
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
the CM Storm Scout 2
http://www.ncix.com/detail/cooler-master-cm-storm-scout-32-76621.htm
2 front RED led fans front
linus have a review
Scout 2 is good i guess i should get scout 2 what about led fans, which led fans should i install??
there are two pre installed i think
if there are no ones installed you should go with these http://www.amazon.com/Cooler-Master-120mm-Case-R4-L2R-20CR-GP/dp/B0026ZPFBG/ref=pd_sim_pc_28?ie=UTF8&refRID=1JZPWD3AR8FR0C4976PF
Ok....i saw those fans....i have one doubt.... Are those leds static or they spin with the fan????@kola360
