Budget (including currency):  $1800-$2000 USD
Country: America
Games, programs or workloads that it will be used for: FPS, Minecraft, and Productivity
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  Here is my current parts list https://pcpartpicker.com/user/AKS012/saved/#view=HHGKXL. It would really mean a lot to me if you guys can give me some tips on how to fix up my parts list and how to get my budget down to $1800-$2000 USD. I am actually upgrading from a console. I am going to be buying the components somewhere in November, when maybe the components get a bit "cheaper". I really want to play at 1440p, but 1080p is good to. For FPS I want to be +144. Thanks 🙂
https://linustechtips.com/topic/1382673-my-first-build/
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($299.99 @ B&H)
CPU Cooler: Thermalright Peerless Assassin 120 White ARGB 66.17 CFM CPU Cooler  ($54.11 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($74.99 @ Adorama)
Storage: Silicon Power P34A80 1 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Case: MSI MPG GUNGNIR 111M ATX Mid Tower Case  ($89.99 @ Amazon)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Wireless Network Adapter: MSI AX905C PCIe x1 802.11a/b/g/n/ac/ax Wi-Fi Adapter  ($39.50 @ Amazon)
Total: $743.56
Generated by PCPartPicker 2021-10-20 23:10 EDT-0400
than grab this off newegg:
https://www.newegg.com/Product/ComboDealDetails?ItemList=Combo.4373326
https://linustechtips.com/topic/1382673-my-first-build/#findComment-15058308
https://pcpartpicker.com/list/N9cqDc
https://www.ebay.com/itm/154660324195?epid=24048051957&hash=item2402794363%3Ag%3ATToAAOSwtrVhb3hV&LH_BIN=1
Got the price down, and got you a faster computer. Replaced the AIO with a good air cooler, since performance will be similar and it's about half the price. Dropped down to 16GB of faster RAM, you can always upgrade in the future if you do need the extra memory. Went for a lower end motherboard, it's an easy place to save if you don't need the extra features. Swapped the SSD out for something of similar performance but a bit cheaper. Swapped the GPU out for a scalped 3070, they outperform the 6700XT and they're the same price on eBay. I get not wanting to pay a scalper, but it's the better way to go in this market. Swapped the case out for something with better airflow.
https://linustechtips.com/topic/1382673-my-first-build/#findComment-15058310
38 minutes ago, AKS012 said:
Cooler is uneccesary and overpriced, will get smushed by something like a liquid freezer 240 value and performance wise, maybe get a h100i platinum or whatever those things were called if you dont have much rad mounting space but want to have a good cooler for an overclock.
Otherwise just get a cheap tower like se 224 xt or whatever 30$ 4 heatpipe tower cooler you can find
Mb is abit overkill, consider a b550 ds3h ac or pro vdh wifi if youd like a cheap board or a b550 tuf gaming wifi for a midrange mb
Rams are complete utter garbage for that price, get some far superior crucial ballistix (rgb) 3600mhz cl16 rams or for cheaper rams you can get silicon power turbine rgb 3200mhz cl16 for ~120$, you can just overclock the 3600mhz anyways and its not hard to do
Ssd is an overpriced pos, get a gen4 ssd like z440 instead, slightly cheaper and much faster than a sad outdated 970 evo, or if you dont need/care about gen4 then go for a crucial p5 ssd, similar performance to a 970 evo but much cheaper
Corsair rm is a solid high quality unit though iirc i think you can get an 850w rmx for around the same price as the rm and the rmx should be a higher quality psu than the regular rm, you can expect it to last atleast a decade
With all the money saved you can prob get a better gpu like 6800(xt) and/or 5800x
https://linustechtips.com/topic/1382673-my-first-build/#findComment-15058337
