Hi everyone,
Was really curious to see some temperature readouts from my 5950x.
While benchmarking on heaven benchmark I’m seeing my CPU hover around 72C once it’s been running for a about 15 minutes. It never goes past 8% usage and despite that I’m seeing temperatures in that range.
As for cinebench, I’m not seeing even close to the same results. On a multi core benchmark I’m not seeing it going past 63C even at a full load. And on a single core load not past 66C
So it’s a bit confusing how a test not designed to stress my CPU is resulting in higher temperatures. I’m not sure if I have bad airflow in my case but I couldn’t imagine that being true considering my setup.
- No PBO enabled
- No custom fan curves
- GPU boosted to 1800MHz out of the box
- Nvidia Control Panel “Prefer Maximum
   Performance” is enabled.
Any advice would be great. Thank you.
Set Up:
MOBO - ASUS TUF Gaming x570-Pro
CPU - AMD Ryzen 9 5950x
GPU - EVGA 3080Ti FTW3 Ultra Gaming
RAM - 2x 16GB CL16 Crucial Ballistix
Storage - 1x 500GB 980 Pro M.2 NVME
              - 1x 1TB 980 Pro M.2 NVME
CPU Cooler - Noctua NH-D15 (Dual Fan)
Case - Corsair 5000D Airflow
Fan Config - 3 Front Intake, 3 Top Exhaust, 1 Back Exhaust
https://linustechtips.com/topic/1382206-weird-cpu-temps/
My guess would be bad airflow. More fans doesn't equal more better. The three top exhaust, particularly the one(s) closest to the front are likely dumping out your front intake before it even has a chance to reach your components. Additionally, the 3080 Ti is going to be dumping a ton of hot air into your case, particularly towards the CPU.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1382206-weird-cpu-temps/#findComment-15054881
So if that’s the case how can I manage better airflow with the fan set up I have now? As of right now all 6 front and top fans are running off of one PWM chassis fan header utilizing the fan hub that comes with the case. I’m not sure if I’m able to control individual fan speeds.
https://linustechtips.com/topic/1382206-weird-cpu-temps/#findComment-15055802
You'd probably do better removing the front two or even all three top exhaust.
https://linustechtips.com/topic/1382206-weird-cpu-temps/#findComment-15055825
