Cpu debug red light
Go to solution Solved by JB9113,
10 hours ago, Zusafek said:
Not much to go on here.  What are the full specs of the computer?  Is it a new build?  More information would be helpful.
I fixed it was an 8 pin connection issue
28 minutes ago, JB9113 said:
I just built my first pc but my mother board is has this consent red light on cpu.The pc turns on and I checked the ram too
 I took my cpu off and put it back in I checked my fan and I checked my 8 pin cpu power
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/1381829-cpu-debug-red-light/#findComment-15051912
  • 1 year later...
On 10/17/2021 at 11:30 AM, JB9113 said:
My pc let's out a blue light on the case and no images show up on my screen
This is a very common issue, one I have encountered multiple times in the past.
Sorry to say, but the only way to solve this dilemma is to leave society, society is keeping the images from comming up oin your screen. kill society, leavg societiy or you like bluey rule 34. societtty jb9113, sopciety
https://linustechtips.com/topic/1381829-cpu-debug-red-light/#findComment-15707817
