Help with choosing a CPU cooler
Go to solution Solved by nixproducer,
Cheer's plus your profile picture is just awesome :)
thanks if you have any other question feel free to ask or even pm me
Hyper 212 EVO but what is your budget?
Christian and Proud of it
Please read the CoC        My Build Log
No need for an aftermarket cooler, k series cpu, or z87 chipset if you're not going to oc..
maybe around £20-£35
then the Hyper 212 EVO is the best for you
If you don't plan to overclock, I would recommend a 4670 instead of the 4670K and any H87 board that you like. As for the cpu cooler, you won't need an aftermarket one if you don't plan to overclock as the stock cooler adequately cools it at stock speeds. But if you want a quieter cooler, you could go with the Hyper 212 Evo.
EDIT: Just saw your last post when I pressed post. The Hyper 212 Evo would be a good choice for overclocking but overclocking on Haswell depends on your chip and your cooling:
70% of CPUs can clock to 4.5GHz
30% of CPUs can clock to 4.6GHz
20% of CPUs can clock to 4.7GHz
10% of CPUs can to 4.8GHz
Overall you will find most CPUs capable of reaching 44x to 45x with varying levels of voltage.
Source:http://www.hardocp.com/article/2013/06/01/intel_haswell_i74770k_ipc_overclocking_review/6
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
