That squeaking noise is a little disconcerting but I'm guessing that's normal since you said nothing about it. In this case your best bet is to run through the troubleshooting gambit of actions. Try removing a RAM stick, if you have 2 and try booting, try switching RAM slots your current sticks are in. Go through and check every connector to ensure they're secure. Try reseating the RAM, GPU and cables. If all that doesn't work, I'd look into the PSU, CPU or GPU further. Perhaps the CPU needs to be reseated, or one of these parts has gone bad. Hard to say with no system specs/details, which would be helpful for you to post.
System Specs: (Click Expand)
          "Beatrix"
  • CPU AMD Ryzen 7 5800x3D
  • Motherboard GIGABYTE X570 I AORUS Pro Wi-Fi
  • RAM 2 x 16GB Corsair Vengeance RGB Pro @ 3200mhz CL16
  • GPU Gigabyte Eagle RX 6700XT
  • Case Corsair Crystal 280x
  • Storage 1x Samsung 980 Pro (1TB) 1x Samsung 970 Evo Plus (500GB) 1x Samsung 860 Evo (1TB)
  • PSU EVGA G5 850W
  • Display(s) 32" Odyssey Neo G7 & 27" Viewsonic XG2705
  • Cooling Corsair H100i Elite Capellix AIO | 4x QL120 RGB fans | 2x QL140 RGB fans
  • Keyboard Logitech G Pro
  • Mouse Logitech G502 Lightspeed /w Powerplay
  • Sound Logitech G Pro Wired
  • Operating System Windows 11 Professional 23H2
https://linustechtips.com/topic/1381417-problems-with-pc/#findComment-15049230
