PC freezes after I lock or do not use it for some time.
RCM10
Hey guys, if anyone can help me out on this that would be great.
The issue is after I lock the PC, the system just freezes after sometime. Have attached the photo with this message.
It does not throw any error / or BSOD.
I have to power off the system and then start it again.
When I am working continuously I have no issue. It is just that when it goes idle, the system just freezes
I tried reinstalling Windows and still the same issue. I also upgraded to windows 11. I still have the same issue.
Is it because of RAM ? How can I solve this issue?
Updated the BIOS too. MB - Gigabyte X570 Aorus Ultra
AMD 5800x
32gb corsair ram
rtx 3080
I see this in reliability history. Is it because of this ? how can I find which hardware is this
Can you try looking into your motherboard bios settings and look for "C-States" or "CPU Idle Power State" and setting it to DISABLED. Usually it is set to auto but what it does is basically shutting off parts of the cpu while at idle to save power. This may be a case of it shutting down so many parts or dropping the voltage so much that windows essentially crashes
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
i turned off amd cool and quite function too. still having the same issue 😞
shucks, that sucks I can't think of anything else off the top of my head will update if something comes to mind
@berberries i downgraded to F32 BIOS version and i thought this will fix the issue but no
