Hi everyone, I'm trying my first PC build and it is close to completion, but I don't have any display. When I press the power button, the cpu and GPU fans spin to life but I don't get any display of the case fans going. Also, the power light flashes for half a second when the power button is first pressed, and then the PC cannot be turned off without unplugging it.
Got any ideas?
https://linustechtips.com/topic/1379693-my-first-build/
It would-be a good idea to list your PC's specs so we can better assist you....
Thomas
MSI Z490 CARBON FIBER  | i9-10850K@5.2Ghz @1.212v | ASRock OC Formula RX6900XT 16GB | 32GB G-Skill Trident RGB 3200Mhz | Custom CPU and GPU Loop(EKWB, Bykski, Primochill) | EVGA Supernova P3 1200W | 2x 250GB Samsung 980 RAID-0 | 2x 500GB Samsung 870 EVO RAID-0 | 1x 2TB Seagate Barracuda 7200RPM | Phanteks Enthoo Pro2 | 8x CM Sickle Flow 120mm Fans | Windows 11 64 Bit
https://linustechtips.com/topic/1379693-my-first-build/#findComment-15036437
case fan with displays? You mean they dont spin?
Can you turn it off by holding the power button? A single push wont shut it down ofc, you dont have an OS yet.
Desktop benching:
https://linustechtips.com/topic/1379693-my-first-build/#findComment-15036446
Sorry I meant that the fans I have installed in the case won't spin, and I have tried holding the button down for a good ten seconds but that didn't work either
https://linustechtips.com/topic/1379693-my-first-build/#findComment-15036451
Thomas
Hi Thomas, I have a b450m a pro max for Mobo, antec spark 120s for fans, AMD 1600 af cpu, an auros m.2 599gb m.2, and a gtx 1650 super for GPU. Hope you can help.
https://linustechtips.com/topic/1379693-my-first-build/#findComment-15036454
