Car stereo won't recognize all folders on my USB flash drive
I finally fixed the drive now.
聽
Here's what I did:
- Copy the content to my Laptop
- overwrite the whole drive with zeros using dd on Linux.聽
- switched back to Windows and formatted again, this time as "full format" (untick "quick format" in the formatting dialog)
- copied over the backed up files
Step 2 is kinda dangerous, if you are not careful you can wipe the wrong drive and destroy your OS. That's also the reason why I didn't specify this step in more detail. If someone needs a more detailed explanation I can write it up later, just let me know.
聽
Car radio scanned the drive for a few seconds, working fine now.聽
聽
Note:
I also left out one folder that contained an unusual character "每" so I'm not 100% sure if the new format procedure fixed it or if it just really disliked that one folder. The manual of the radio聽states that it might not correctly display unusual characters, so it seems to have a limited charset.
聽
But I'll definitely check that last bit and edit this post as soon as I know for sure.
聽
EDIT: It actually was that one folder with the "每" character. I guess UTF-8 support is too much to ask in 2021... *sigh*
聽
Thanks for all your ideas 聽
