Hyper 212 EVO thermal paste question
25 minutes ago, tkitch said:
no you cannot.
Don't use liquid metal on heatsinks.  Full stop.
I have the OG 212 EVO (not the new version),and the cold plate is basically just bare copper heat pipes
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
yet parts of the base plate, including where hardware mounts are, are aluminum.  You wouldn't know there was damage until the entire cooler gave out.
Bad plan.
Bad plan.
You misunderstood me,
Don't mind that misunderstanding,everything you said is true anyway,
I have an old 212 too, and there is definitely aluminum on the outside of those copper heat pipes.
