I added 4 gb ram stick to my laptop
And after that new problem started in my laptop
Now sometimes when i start my laptop it dose not start and only when i plug charge and start then only it starts
And sometimes if laptop is on i remove charging plug it immediately turns off and do not start until i plug in charge
I checked battery connection its completely fine
This problem occurs sometimes other times laptop works fine
But if i remove the new ram stick then laptop works fine like there is no problem at all
Laptop: acer aspire 5
i5 8***U
Mx 150
New ram : crucial 2600mhz 4gb
Help needed
https://linustechtips.com/topic/1378574-weird-issue/
It might also be a bad/dead battery given the laptop only worked when plugged into the wall. Would be a coincidence to start happening after RAM install, but removing the new stick to see if the problem still happens would tell you that pretty quickly.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1378574-weird-issue/#findComment-15028907
