Problems using NTLite
Go to solution Solved by kris44dad,
Figured it out...
 I'm trying to use NTLite (v 2.3.0.8333) so I can add some drivers to a Windows install iso.  The tool keep saying, invalid Windows image path.  The error box says to mount the iso and copy the Windows files to a folder. I did that, and the tool gives the error. Obviously missing a step here.
https://linustechtips.com/topic/1377902-problems-using-ntlite/
