Hello everyone,
I've built 2 pc's for a dual pc setup so that I could have my games at higher settings and so that my twitch stream would not start to drop frames like crazy, but for some reason it still does.
Gaming PC        Stream PC
i9-9900K not OC at the moment                                                               i5-9600K
32 GB RAM @ 3200        16 GB RAM @2400
RTX 2070 Gigabyte Windforce not OC at the moment                             GeForce GT 730
ASUS ROGSTRIX Maximus Xl        Asus MB (idk the exact model but non OC)
750 WATT EVGA GOLD PSU        650 Watt PSU
        Elgato HD60 Pro (PCIe)
I use OBS on my stream PC and have my main monitor (1080p 144hz)  on my gaming pc duplicated going back to the elgato in the stream pc (settings in the images). I have gig internet going to both pc's. My audio isn't an issue as I use Voice Meeter Banana and that doesn't give me problems. I tried using the videos I found on google, and they make it seem like no issue but mine when I try it drops frames. I try games like Rocket league and even in that kinda game my frames drop on OBS and the stream is unwatchable at times.
Please let me know if you need any other info.
Thanks!
https://linustechtips.com/topic/1377850-dual-pc-stream-problems/
3 hours ago, Revoked Saint said:
Hello everyone,
Gaming PC        Stream PC
Thanks!
a 730 is really bad... https://gpu.userbenchmark.com/Compare/Nvidia-RTX-2070-vs-Nvidia-GeForce-GT-730/4029vsm12582
maybe wait till the gpu crisis is over and then buy a 3060
-> Moved to Programs, Apps and Websites
Have you tried to encode with CPU instead of GPU? CPU encoding is usually dismissed in one PC setups as its used by all resources (OS, background software, game, streaming software). Which is why using GPU to encode is usually better choice. That doesn't mean it would be bad choice when you don't have anything else but encoding (plus OS ang bg software) for it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
It for the stream PC I don’t think I need a 3060 for just encoding.
I believe I have and when I tried steaming a fast paced game like apex or war zone. The frames drop like crazy.
