Cable mod for NZXT c850
Go to solution Solved by Snoowy,
So I’m getting a NZXT C850 Gold power supply and I’m a bit confused on what cable mod set to get. I’ve checked the compatibility list and the C850 wasn’t there so I asked about it and they said I need to get cable extensions but I don’t know if I am meant to get the 8+8 pin set, 8+6 pin set or the 6+2 pin set. This is my first build so I just want to make sure I know witch one to get so I don’t blow up my power supply.
thanks in advance.
thanks in advance.
https://linustechtips.com/topic/1377248-cable-mod-for-nzxt-c850/
