need help with my first build
Solved by BeastyB314,
Don't get the 9900K. I got the 9700K and now I can't upgrade without a new mobo. Try to get a 10th gen as that gives you room to upgrade cpu wise.
Have fun trying to get a 3080 for less than a grand. Look for a 6700XT or a 6800 XT as they are cheaper and have better performance. They are also easier to find.
Ramrod126 ·
Posted in Cases and Mods0 -
smush ·
Posted in CPUs, Motherboards, and Memory4 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
1
1
