I bought a Logitech MK220 wireless combo in July 5th for my PC.
Sometimes the keyboard and mouse's getting stuck at, which means I can't do anything but when the mouse and keyboard came back to normal the commands (or the things I do) all happens when it came back to normal. (as a example - If I typed 'Hello' when the keyboard is stuck it will type after the keyboard came back to normal) and this problem occurred in August (which month after the purchase). I thought this might be a problem of the battery because I use the battery inside the keyboard and mouse box.
At that time the problem mostly occurred in the mouse so I change the mouse batteries, It worked fine.
But again today it started to happened, do you guys know why is this happening?
https://linustechtips.com/topic/1377020-keyboard-and-mouse-help/
Yes.
Then one month later...
The battery was empty:
Then another 1-2 months later (now):
Surprise!
The batteries will probably be empty again...
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
3 hours ago, suedseefrucht said:
Yes.
Surprise!
What???
Does batteries only last for 1-2 months??
And also in the Logitech box if I'm correct it says that the battery will last for 6 months...
and also if the batteries are dead how does the things I typed will happen after the keyboard came back to normal??
Last time they lasted 1 month too... So in your case apparently yes.
If they go back to normal, they are like almost dead. I guess the keyboard has a buffer collecting your typed keys to keep them until they were sent successfully.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
What???
If you dont like swapping batteries, wired mice have a 100 % good connection, they always work and they never disappointed me.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
