New mouse - I need help!
Go to solution Solved by Guest,
I recommend the M45, great mouse for the money.
Hello people!
Let me start off with some introduction. I got a Logitech G600 mouse right now (that is the giant one with billions of buttons). I bought this one back when I was only playing League of legends, which I stopped playing now. I moved on to BF4, CS:GO and other FPS games and the G600 is not really good for that. So I need some help with finding a new mouse. accuracy and enough buttons (that is at least 3 buttons not counting right and left click) is the most important for me, but many things are important.
To make your job a little easier, here is some info for you:
- I prefer claw grip or maybe fingertip, but I'm not gonna get a palm grip mouse.
-my hand is about 17 cm (that is about 6,7 inches) from the longest finger to where the wrist starts.
-As I said, I play alot of FPS games so I don't need ALOT of buttons, but I would like to be able to tag people in bf4 with my mouse, while still being able to switch weapons and maybe also throw grenades.  and if possible even more without getting uncomfortable.
-My budget is 78,52$/56,92€/46,89£
-I have been looking into these mice, but I don't mind suggestions:
   - CM Storm Spawn
   - CM Storm Reaper (more than my budget, but might save up for it if it's worth it)
   - CM Storm Recon
   - Corsair Raptor M45
   - Roccat Kova+ / Kova Pure
   - Roccat Kone Pure
Just ask if you want to know anything else, but other than that I hope that you can help me find a mouse that I will enjoy. Thanks in advance.
https://linustechtips.com/topic/137652-new-mouse-i-need-help/
I have a similar size hand, prefer the same grip and have the Roccat Kova, it fits pretty well. The M45 should be great too.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829021
I recommend the G400S, its a great mouse :D if you can spend a little more, look in to the logitech G500s :D i have it and it's absolutely amazing
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829023
You can find the deathadder 2013 for as little as £45 on amazon every now and again.
CPU  Intel i7 5820k Motherboard Asus X99-S  RAM  32GB (8x4) Kingston Hyper X Fury GPU EVGA GTX 1080Ti SC2 iCX Case Fractal Design R4 Windowed Storage 500GB Samsung 850 Evo + 120GB Crucial M500 SSD + 2TB Seagate Barracuda + 1TB Western Digital Blue PSU Corsair RM1000 Display 2x Asus VS239HV Cooling  Noctua NH-D15 Keyboard  Corsair K70 RGB Mouse Logitech G502 Gaming Surface Razer Golitahus Extended Speed
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829061
G400s. It has the great logitech shape and is one of the best mice for FPS. Just don't buy a laser mouse and you will be alright.
for £89 you  can go get youself the Deathadder 2013, By far the best optical mouse out in the market. But whatever you get make sure its optical
Guys, not trying to be rude but all those are palm grip mice.
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829247
I think I'll go with this, at first I thought it would be too big, but it seems that it might be fine and the looks are pretty amazing!
Oh! And weight system is pretty cool.
Edited by SplifD
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829283
I tried the Roccat pure optical and I found that to be a claw grip mouse. Give that a shot I am a hybrid palm/claw grip and I found the DA2013 to be the best for me. even when I claw grip it.
Quack 🦆
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829323
MadCatz Cyborg Gaming R.A.T. 3 would be the perfect choice in this case.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829346
I might have no reason at all, but MadCatz seems to me as being just too gimmicky.
Adjustable, fingetip/claw grip optimized, flawless sensor (optical, older series with laser is not so good) and OK quality - I don't see why not consider it.
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829508
Logitech g602 (works fine for claw/fingertip) or the new logitech mouse when it comes out if its good
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829518
Well as long as it is not Laser I approve :P
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829523
I went through several mice before I finally became satisfied and settled with the G400s.  Great mouse.  Comfortable and accurate.  Highly recommend this mouse.
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1829893
As a claw-grip user with a smaller hand I can't recommend anything from the Logitech MX-510/MX-518/G400/G400s/G500/G500s. These mice were never comfortable for me, after some time of using my wrist would be painfull.
https://linustechtips.com/topic/137652-new-mouse-i-need-help/#findComment-1830039
