Budget (including currency): Max $1900 USD
Country: USA
Games, programs or workloads that it will be used for: Gaming, content creation/streaming, school (web development)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Don't need peripherals.
https://pcpartpicker.com/list/Z84kVc
I looked at some of the feedback for my last parts list and cut some costs and switched some parts and don't think there is anything else I want to change as of right now.
Think this build is better and will be a decent pc while remaining a decent cost. I realize I probably will have to update the BIOS, but other than that should all of this be compatible?
I was also wondering if it would be worth building now and if I could put my 1060 3gb in it until GPU market fixes a little bit. Would that be compatible?
Since I cut costs I left some spare room for a possible 3080, but most likely will spend the saved money on a new desk.
https://linustechtips.com/topic/1376115-changes-to-my-first-build-design/
cheaper but parts are just as good:
PCPartPicker Part List
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($393.99 @ Amazon)
CPU Cooler: Gelid Solutions Phantom CPU Cooler  ($36.99 @ Amazon)
Motherboard: Asus ROG STRIX B550-F GAMING ATX AM4 Motherboard  ($159.99 @ Newegg)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-4000 CL18 Memory  ($140.00 @ Newegg)
Storage: Silicon Power P34A80 1 TB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon)
Video Card: NVIDIA GeForce RTX 3070 8 GB Founders Edition Video Card  ($499.99)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply: MSI 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Amazon)
Total: $1520.93
Generated by PCPartPicker 2021-09-26 07:24 EDT-0400
Total: $1520.93
Change cooler to scythe fuma 2 and that's all.
