you need a Female XLR panel mount connector
A SATA Power Extension (I'd use SATA over IDE.  Nobody wants IDE in the case anymore.)
And a USB Motherboard Header Extension cable.
And then do a little soldering.
What're you trying to figure out?  This is pretty simple, and they laid out pretty good directions.
https://linustechtips.com/topic/1375220-custom-cable-request/#findComment-15006346
