Country: EU
Games, programs or workloads that it will be used for: AAA high-ish settings, 60fps; esports 240fps; both at UHD
Pretty sure I want to go for this CPU/GPU combo. I already have the 3060Ti and doubt will use more than 6C/12T.
I don't want to replace cooling, case, SSD and PSU for many years, while upgrading CPU+motherboard, RAM and GPU as needed.
Please share your thoughts.
https://pcpartpicker.com/list/CR8QXb
https://linustechtips.com/topic/1374711-thoughts-on-my-build/
Looks great!
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1374711-thoughts-on-my-build/#findComment-15001030
10 minutes ago, phastasmn said:
Country: EU
This is a pretty good parts list, there's only two things I would personally change.
1.) The PSU. Since you want to keep this PSU for many years, you might be better off going for an 850w, that way if you try to get say a 3090 when they're finally cheap on the used market, you can. The RM850x is only $25 more, and if you're gonna keep it for a while, I'd say that's worth it.
2.) The Motherboard. I'm not a fan of Gigabyte motherboards for a variety of reasons, one of the bigger ones is their complete lack of debug LEDs on anything but their top end boards. The B550 Tomahawk is also a fine motherboard for $15 cheaper that I would personally use instead.
That being said, if you went with that system in its current config, It would be more than fine for a number of years.
https://linustechtips.com/topic/1374711-thoughts-on-my-build/#findComment-15001035
9 minutes ago, phastasmn said:
Country: EU
The 3060Ti might be a little underpowered for UHD 60 FPS
I avoid Gygabyte products personally because of poor costumer relations. I'd go with an ASUS TUF instead.
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
https://linustechtips.com/topic/1374711-thoughts-on-my-build/#findComment-15001044
Absolutely! Thanks for your detailed recommendations.
How bad is the Gigabyte though? In my local market I would need to pay significantly more (almost $100) for anything else that supports front USB-C. Is it still not worth it?
Right, I meant QHD.
https://linustechtips.com/topic/1374711-thoughts-on-my-build/#findComment-15011747
Not bad enough that where I'd say to spend an extra $100 to get something else. Just be warned that their motherboard quality is very hit or miss, since most of them don't have debug LEDs diagnosing a problem is a real challenge, and their customer service is a bit of a joke.
https://linustechtips.com/topic/1374711-thoughts-on-my-build/#findComment-15011959
