Want to connect a livelier microphone and a bluetooth headset at the same time.
Solved by tkitch,
All you have to do is go into windows sound settings and specify what device you're using for a mic. It's pretty easy.
You can get a Y cable that'll turn a combo headset jack into separate headphones and mic plugs, that may fix it, too?
Featured Topics
Prajnaanicca ·
2
ZGruk ·
Posted in New Builds and Planning2 -
Cramig88 ·
Posted in Networking0 -
7
Xnihilo97 ·
Posted in Peripherals0 -
