Hey everyone, I'm new here, so sorry if this has been covered before (no search function on the forums?). I was looking at cases that I may want to move my system into in order to go to an HTPC setup and I ran across the Raijintek Pan Slim. I almost jumped on it because it's almost exactly what I've looking for. However, after thinking about it a while I noticed the unusual orientation of the AIO (see below), and I remembered that a couple of youtubers had done videos on this subject (Stop Doing It Wrong!). After re-watching the videos I started thinking that maybe this wasn't the case that I've looking for, I don't think either of the videos covered this exact setup, but now it just looks weird to me. Let me know any thoughts on this issue please. And thanks!
Edit: Found the search function, sorry.
https://linustechtips.com/topic/1374648-aio-orientation/
Do you know if there is a mounting point where the radiator fits above the pump?
Mockups and renders of cases that have plenty of top/front/back radiator support have depicted the cardinal sin of bottom mounting before, so it's not completely insane that this case has a mounting position where the radiator is above the pump, even if the difference is only a marginal delta z.
It's entirely possible that I misinterpreted/misread your topic and/or question. This happens more often than I care to admit. Apologies in advance.
珠江 (Pearl River): CPU: Intel i7-12700K (8p4e/20t); Motherboard: ASUS TUF Gaming Plus Z690 WiFi; RAM: G.Skill TridentZ RGB 32GB (2x16GB) DDR4 @3200MHz CL16; Cooling Solution: NZXT Kraken Z53 240mm AIO, w/ 2x Lian Li ST120 RGB Fans; GPU: EVGA Nvidia GeForce RTX 3080 10GB FTW3 Ultra; Storage: Samsung 980 Pro, 1TB; Samsung 970 EVO, 1TB; Crucial MX500, 2TB; PSU: Corsair RM850x; Case: Lian Li Lancool II Mesh RGB, Black; Display(s): Primary: ASUS ROG Swift PG279QM (1440p 27" 240 Hz); Secondary: Acer Predator XB1 XB241H bmipr (1080p 24" 144 Hz, 165 Hz OC); Case Fans: 1x Lian Li ST120 RGB Fan, 3x stock RGB fans; Capture Card: Elgato HD60 Pro
翻生 (Resurrection): CPU: 2x Intel Xeon E5-2620 v2; Motherboard: ASUS Z9PR-D12 (C602 chipset) SSI-EEB; RAM: Crucial 32GB (8x4GB) DDR3 ECC RAM; Cooling Solution: 2x Cooler Master Hyper 212 EVO; GPU: ASRock Intel ARC A380 Challenger ITX; StorageCrucial MX500, 500GB; PSU: Super Flower Leadex III 750W; Case: Phanteks Enthoo Pro; Expansion Card: TP-Link Archer T4E AC1200 PCIe Wi-Fi Adapter Display(s): Dell P2214HB (1080p 22" 60 Hz)
壯麗 (Glorious): Mainboard: Framework Mainboard w/ Intel Core i5-1135G7; RAM: G.Skill Ripjaws 32GB (2x16GB) DDR4 SODIMM @3200MHz CL22; eGPU: Razer Core X eGPU Enclosure w/ (between GPUs at the moment); Storage: Samsung 970 EVO Plus, 1TB; Display(s): Internal Display: Framework Display; External Display: Acer (unknown model) (1080p, 21" 75 Hz)
https://linustechtips.com/topic/1374648-aio-orientation/#findComment-15000623
End of the day, its probably not ideal for the lifespan of the pump but it'll work.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1374648-aio-orientation/#findComment-15000633
