When I ran across this same situation after buying my NVME SSD, I used the software in the link below.  It works great and best of all, there is a FREE version that works.  It's called AOMEI Partition Assistant, and you can download it here.
https://www.diskpart.com/free-partition-manager.html
Just don't forget to click the "APPLY" button in the upper left corner in-between the different steps.
Good Luck.
