do you want it or is the problem?
i5-9400f
corsair 16gb (2x8) kit + 4x1 gb microsoft stick both 2666
asrock b350m pro4 lga 1151
intel ax-210 wifi card
msi rx 580 8gb
nzxt h510 airflow case white
650w thermaltake gold
512gb nvme
1tb wd blue
1tb seagate external
https://linustechtips.com/topic/1373442-audio-from-keypress/#findComment-14991696
-> Moved to Programs, Apps and Websites
There are probably some older software to do this. Look for "soundboard". In OBS, you can set hotkeys to play sound clips. The setup overall is bit tricky, but will work fine. You are adding each soundfile as Media in Sources. Then set hotkey to replay the clip.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1373442-audio-from-keypress/#findComment-14996236
