So I am going to getting a pair of Sennheiser HD 600 and was told I would need to get a DAC. I have a 3 PC setup currently. Gaming PC, Secondary PC I let friends use for LANs but use this with Synergy Mostly watching Streams and Videos and now I have a work laptop. I would like to setup a way that I can use my new headphones to listen to all 3 computers at the same time.
I also have an XLR mic that I would like to use between two of them but do NOT want to hear myself speak or monitor the mic at all. I do not know anything about audio and am looking for help and suggestions on what I would need to make this possible. Any help would be greatly appreciated.
https://linustechtips.com/topic/1373354-help-with-audio-setup-please/
Well, plug them in. If you notice too much noise, get a DAC.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
Plug in all the computers, and then turn them all on.  After they all boot up, turn the volume up all the way and crank out some Led Zeppelin, AC-DC or something similar.  Just make sure that everything is maxxed out as loud as can be.
headphone is easy, get yourself a good mixer that have atleast 3 stereo input (6 if all of the input is mono)
mic?, yeah that part is not so easy especially since it was an xlr mic, unless you want to unplug and plugin the audio interfaces everytime you want to switch to another pc
maybe take a look at audient id4 mkiikomplete audio 6 mk2 or audiobox usb 96
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
This is probably the most professional and cheapest solution. It has an ADC and a DAC.
There are larger models with more inputs but this one is a very hi quality unit comparable to very expensive DACs.
I am a sound engineer for a very long time ( I have a long grey beard).
https://www.behringer.com/product.html?modelCode=P0AVV
Behringer U-Phoria UM2 | whybuynew.co.uk
