Hi,
I am going to upgrade my CPU, motherboard and AIO cooler and i want to make sure that everything will work together.
The CPU i am using is a ryzen7 3700x, The motherboard I am using is the Gigabyte B550M AORUS PRO-P micro ATX and the cooler I am using is the Artic liquid freezer || (120mm)
I think the cooler should be ok to handle the CPU temps but I am a little concerned about motherboard and cooler clearance issues.
Thanks.
https://linustechtips.com/topic/1372506-cpu-cooler-compatibility/
12 hours ago, benkellyh544 said:
thanks, any recommendations?
Air Coolers:
Scythe Mugen 5
Scythe Fuma 2
Noctua NH-U12S
Be Quiet! Dark Rock Pro 4
240mm AIO:
ID-COOLING ZOOMFLOW 240X ARGB
Corsair H100x
be quiet! Pure Loop 240
You can check reviews of different AIO's before you buy them. Their quality seem to vary quite a bit.
3 hours ago, benkellyh544 said:
i am upgrading my motherboard and cpu, along with my AIO cooler. I am going for a ryzen 7 3700x
I don't get it, In first post you said you are using 3700X and B550 motherboard, Now you are saying you are going for it, What does that mean? I'm confused.
