-12volt on power supply acting weird and +12 in hwmonitor is weird and high idle cpu usage
Solved by Somerandomtechyboi,
Yep garbage psu
Ive actually experienced the same thing, though in my case the 12v and 5v were like ~13-14v ~5.5-6v but 3.3v was at 2.8v
It caused my e5400 to run at ~1.7v on idle but on load it runs the voltage id expect (~1.55v) and this was an attempt at a 4.5ghz overclock
Swap your psu now before the stupid thing causes the cpu to run at 1.9v or some stupid sht like that
