Hey guys just looking for a good USB hub that I can either mount on top of my desk / possibly on the underside, either with built in mounting holes or just some double sided tape.
My motherboard 1x USB 3.2 gen 2 type a and 1x USB 3.2 gen 2 type c so either connector will do.
As far as ports go 4x USB's would be pretty sweet and then maybe an ethernet port or too as well. No super concerned budget wise so long as it's not like 200$ lol.
Data Systems Administrator | Sergeant - US Marine Corps | CCNA / SEC+
Ryzen 9 5950x | 64 GB DDR4 3600Mhz | Gigabyte RTX 3080 Ti | Full Build Info | HomeLab Setup
https://linustechtips.com/topic/1370091-best-usb-hub/
  • 3 weeks later...
I use this one:
https://www.amazon.com/ENHANCE-Gaming-Mouse-Bungee-Holder/dp/B074XKRKL1/ref=sr_1_6?dchild=1&keywords=mouse+bungee+rgb&qid=1632334998&sr=8-6
Hubs are not good for file transfers and peripheral hard drives, but for mice, keyboards, controllers, this has worked great.
https://linustechtips.com/topic/1370091-best-usb-hub/#findComment-15004843
