Display port to VGA or DVI?
Solved by YoungBlade,
DisplayPort to VGA or DVI is going to be cheaper than converting from HDMI.
The problem with DVI is making sure it's the right type of DVI connector, but DVI will allow for higher resolutions than VGA, so it may be necessary. Then again, if your monitor is just 1080p 60Hz, VGA is sufficient.
Also, DVI might look better if it's digital DVI, because you aren't converting it to analog, but if it's analog DVI then that won't be a difference.
It's confusing stuff like that that gives me no nostalgia for DVI. It was an overly complicated connection.
