So I have built a new pc and I’m newer to it so I built it in March this year and now it’s currently showing me a cpu red light saying my cpu is burnt now mind u I saved up money so I can’t jus go buy new parts back to back right ?
So everything comes on literally everything expect my mouse keyboard and it doesn’t post or even come up at all jus black screen but the whole computer be running
my specs are these now mind u all parts were bought brand new either out bestbuy or off newegg in February built beginning of March ran perfectly til bout 4 days ago woke up the next day to it doing the cpu light but will run everything jus won’t post
ryzen 7 3700
msi mpg x570 carbon gaming WiFi
msi rtx 2070 double fan 8g gpu
1 tb hard drive
500gb ssd
16 gb of ram
https://linustechtips.com/topic/1369275-i-need-help-pc-not-posting/
So CPU is ruled out... means Motherboard failure.
those parts should still be under warranty right?
As long as you didn't screw something up and the board died on its own, you should be able to rma it with MSI or bestbuy/newegg.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
