I really have no understanding of those things whatsoever, hence I'm asking this. Why doesn't the RPM of System fan 1-3 ramp up when the CPU is under more load? And What exactly is the 'CPU OPT FAN' Something is plugged in on the 'CPU OPT FAN', I think I connected something of my CPU liquid cooler there.
https://linustechtips.com/topic/136900-system-fans/
Why do the specs of my Corsair sp120 fans say '2400 rpm' then? When will they ramp up to a 2400rpm ?
When they are under heavy load, the will speed up to keep everything cool?
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/136900-system-fans/#findComment-1818818
They don't, I just stress tested and bechmarked the CPU, the rpm didn't change, only the cpu cooler ramps up
Well then they don't need too then. Only reason why my case fans change speeds for me is cause i have a fan controller. Your cpu fans should always change in speed as it depends on how much load it is under. If the other fans are plugged into your psu for example they will just spin at max rpm and not change.
https://linustechtips.com/topic/136900-system-fans/#findComment-1818828
I can manually set the RPM of my System fans, and the CPU fan obviously changes in speed whenever the CPU is under load.
https://linustechtips.com/topic/136900-system-fans/#findComment-1818834
Ok so what is the problem? If they are plugged into your mobo you can change it in bios.
https://linustechtips.com/topic/136900-system-fans/#findComment-1818846
Sys fans spin at constant rpm which is bit under (I'd say 200rpm) rated max. You can set them to follow CPU fans curve with software like Speedfan or mobos suite. CPU_OPT header is for 2nd fan for tower coolers or for AIO pump/fans. It uses same temp sensor as CPU_FAN so it gives same amount of power to both fans.
The Corsair fans... I don't really know why you'd want them to blow at max if they do good job when not at max. If you want then to run at full speed, connect them to PSU.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/136900-system-fans/#findComment-1821416
