I just finished build my father his new pc and right at the time to install the thermal paste the last tiny amount of mx4 came out and I had to add on top of it some of the terrible paste that came with the box is mixing paste going to harm the 3600x or not I have a order of some new mx4 on the way should I clean it off now or wait till the new paste comes
Main Pc: CPU: ryzen 5 5600x  Motherboard: Msi b450 gaming plus max  RAM: 32gb corsair vengeance ddr4 3200mhz ram  GPU: Nvidia rtx 2070 SUPER 8gb Case:  cooler master td500   PSU: corsair 750watt bronze80+  Cooling: Kraken x53 aio Storagewdblack snd750,3tb wd blue hdd
2nd Pc: CPU: ryzen 5 3600 Motherboard: Gigabyte AB350M-Gaming 3  RAM: 16gb 3000mhz gskill Aegis  GPU: Nvidia gtx 1650super 4gb  Case: Cooler Master MasterBox MB311L ARGB Airflow PSU: corsair cx 550watt 80+ bronze Cooling: Vetroo V5 CPU Air Cooler Storage: adata su635 240gb ssd, seagate 750gb 7200rpm hdd
3rd pc CPU: i7 2600 Motherboard: asus H61M-E  RAM: 16 gb ddr3 1333mhz GPU: nvidia gtx 1060 3gb Case: thermaltake versa h18 PSU: evga 450watt 80+ bronze Cooling: Cooler Master I70C (Copper Core) Mini CPU Cooler Storage: crucial mx 500 500gb ssd, wd blue 1tb 7200rpm hdd
https://linustechtips.com/topic/1368951-thermal-paste-issue/
should be fine. I had to mix pastes on a build recently for the exact same reason and temps are A OK.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1368951-thermal-paste-issue/#findComment-14959267
Imagine mixing different detergents - they may work better together and some may say they do, but if they won't - you'll know about it too late.
You'll be alright for the meantime, but changing it to one compound is heavily prefered as it makes stuff more predictable when it will eventually start to dry
Futureproof your builds and try not to fry anything
https://linustechtips.com/topic/1368951-thermal-paste-issue/#findComment-14961666
