MB: gigabyte Vision G z590-A Prime
CPU- i7-11700K
PSU- Asus ROG 850G
RAM- Corsair Vengeance RGB Pro SL 4x8GB 3600Mhz DDR4
I have checked the CPU for Bent pins-none
I have tried single modules in A2 B2 A1 B1 I have tried a different module of LPX 1x8gb 3000Mhz
I have done a CMOS clear
I cannot get the PC to POST
I am unclear on the BIOS version as this is a brand new build.
Help me please
https://linustechtips.com/topic/1368249-dram-error-pc-wont-post/
CPU- i7-11700K
PSU- Asus ROG 850G
Help me please
If nothing works in it it's possible the board or CPU are DOA (dead on arrival), it's rare but does happen from time to time. Have you got any other memory sticks to test it with?
Yours faithfully
I have tested it with alternate memory modules and it's the same result
  • 2 weeks later...
Sorry for the belated reply, I'm afraid the best course of action is to send both back and state that either or both might be faulty, that's easier if you bought from the same shop as they can then easily process the RMA internally for the defective part, if you haven't already done so
Yours faithfully
