im looking for a quailty white matx case that fits a full size psu
do you guys know of any cases like this
Main Pc: CPU: ryzen 5 5600x  Motherboard: Msi b450 gaming plus max  RAM: 32gb corsair vengeance ddr4 3200mhz ram  GPU: Nvidia rtx 2070 SUPER 8gb Case:  cooler master td500   PSU: corsair 750watt bronze80+  Cooling: Kraken x53 aio Storagewdblack snd750,3tb wd blue hdd
2nd Pc: CPU: ryzen 5 3600 Motherboard: Gigabyte AB350M-Gaming 3  RAM: 16gb 3000mhz gskill Aegis  GPU: Nvidia gtx 1650super 4gb  Case: Cooler Master MasterBox MB311L ARGB Airflow PSU: corsair cx 550watt 80+ bronze Cooling: Vetroo V5 CPU Air Cooler Storage: adata su635 240gb ssd, seagate 750gb 7200rpm hdd
3rd pc CPU: i7 2600 Motherboard: asus H61M-E  RAM: 16 gb ddr3 1333mhz GPU: nvidia gtx 1060 3gb Case: thermaltake versa h18 PSU: evga 450watt 80+ bronze Cooling: Cooler Master I70C (Copper Core) Mini CPU Cooler Storage: crucial mx 500 500gb ssd, wd blue 1tb 7200rpm hdd
https://linustechtips.com/topic/1368123-need-help-find-case/
Budget? What is your cooler size?
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
https://linustechtips.com/topic/1368123-need-help-find-case/#findComment-14953318
im looking for around $120 if possible and a tower cooler the size of a hyper 212
https://linustechtips.com/topic/1368123-need-help-find-case/#findComment-14953321
https://linustechtips.com/topic/1368123-need-help-find-case/#findComment-14953334
https://linustechtips.com/topic/1368123-need-help-find-case/#findComment-14953340
2 minutes ago, Coruption said:
any without popuot pcie brackets
wdym? like without a pcie riser, or without the gpu slot?
https://linustechtips.com/topic/1368123-need-help-find-case/#findComment-14953345
Just now, OhioYJ said:
I thought they meant the break away covers like on the S100 you linked to? That was my interpretation.
can i replace them with screw in ones
https://linustechtips.com/topic/1368123-need-help-find-case/#findComment-14953355
yes there are generally screw in replacements
https://linustechtips.com/topic/1368123-need-help-find-case/#findComment-14953356
Amazon Example Link in White (since both cases above are white):
10 PCI Slot Cover Dust Filter Bracket Expansion Blank Plate Shield Metal White
There are a pretty wide variety available, especially in black, mesh, slotted, it's just a PCI slot cover. Order them when you order the case if it bothers you that much. Like I said not a deal breaker necessarily.
https://linustechtips.com/topic/1368123-need-help-find-case/#findComment-14953360
