Case fan upgrade help
Solved by Bombastinator,
10 fans is probably too much. Even 7fans which would remove the fans of a 360aio is still probably too much.
The big issue with rgb/argb is compatibility. You need to make sure that your case and all the stuff in the case has a way to be powered and a way to be controlled, and compatibility isn’t guaranteed even sometimes within a brand. Without knowing the case and motherboard there really isn’t a way to tell if they will be compatible with each other with rgb, let alone if some cooler will be. The whole concept has become a big mess. I have been given to understand that argb fixed this to a certain extent. I’m not sure to what degree though.
