Old System Upgrade
Solved by GeorgeMKane,
You should definitely consider upgrading your cpu, motherboard, ram, and probably your case as well. I know you said you want to keep the same motherboard, but it wouldn't be worth it to only upgrade one generation.
I would recommend saving up some money, and going for either a Intel Upgrade or Ryzen upgrade.
You'll definitely be looking at the used markets for gpu's, if you want anything within a decent price.
