are there any wired mice with detachable cables? I end up swapping the mouse between 2 computers right next to each other and thought it would be easier to just have 2 cables already plugged into the computers and be able to swap from the mouse side instead of the back of the computer, like I do with my razer black widow. But the only ones seem to be wireless, and even then some only use the wire for charging instead of mousing.
https://linustechtips.com/topic/1367661-detachable-cable-wired-mouse/
Id just use a Wireless mouse instead, maybe something from Logitech like the G Pro Superlight. Most of the wireless Logitech mouses come both with bluetooth available but also a USB receiver.
You can change between bluetooth or USB receiver with a button on the underside of the mouse, which would allow you to use it between different computers by just switching the mode.
