I need help
Solved by Kaikidna,
7 hours ago, bmx6454 said:could try running cmd, and entering "sfc /scannow", see if that finds anything. could check system configuration > services, click "hide all microsoft services", and see what's running, and unselect anything you don't want/need running. you mention multiple malware services, imho defender is more than enough, unless you are going to sites, or using software, that is less than ideal... what is the malware programs you are using? last resort would be fresh windows 10, that would likely fix any issues, unless your hdd is just old and tired and needs replacement.
The fresh restart worked everything is running great now. Thank you.
