Totally fine. If you have a 500 series Board, B550 or x570, you should look into the Curve Optimizer with PBO2 to getting a performance boost and lowering your temps.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1367542-5900x-temps/#findComment-14949268
  • 1 month later...
It does seem a bit warm to me. I am in a 20.5c space right now. This thing has been running World Community Grid for a couple of days now since I last rebooted.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1367542-5900x-temps/#findComment-15047669
9 minutes ago, YoungBlade said:
But don't you run it with an undervolt?
+150 all core, -30 CO
I was running +200 just fine for months, but had some issues in 11 so I knocked 50MHz off the top. Its not really an undervolt, you are just manipulating curves. I still see the same voltage used with this OC and stock. Outside of that I have not touched vcore or LLC, I only do for all core clocking.
Edit:
I do use LLC on the SOC after a certain point.. level 3 + 20%
https://linustechtips.com/topic/1367542-5900x-temps/#findComment-15047693
