old system needs some help
Solved by jaslion,
49 minutes ago, George Caso said:Okay I had to pull out the psu to see the brand and p/n EVGA 100-W1-0600
Budget? maybe $100.00US if I'm lucky
Oof yeah not a good psu so big gpu limit there.
Best you can do is a r9 270(x) or gtx 760. Neither is a good card but since you did not specify what you want to do this is all I can give you for now.
