So I decided to replace the thermal paste from the CPU(R5 3600x) with a better one and after everything was done, the pc wouldn't boot. The CPU light on the motherboard was red, it usually lights up and goes down to the other 4 but this time it was just staying at the CPU light.
I double checked the cpu pins, they were fine. I did push a bit harder on the cooler (cooler master 212 evo, installing it is a pain) but when i took the cpu out to check the pins there were no signs of damage to the cpu or the motherboard(B450 Tomahawk max)
I tried to:
Check the cpu power cable
Check the motherboard power cable
Slightly unscrew the cpu cooler
Screw the cooler a bit tighter
Reset CMOS (took the battery out for 10min 30 min and a few hours)
Tried to boot without the gpu
Basically i tried everything i could think of that may help. Any ideas of what could be wrong?
*The table was on carpet but i had a pair of plastic/rubber slippers so i don't think i could have killed it with ESD.*
https://linustechtips.com/topic/1367335-no-boot-after-cpu-thermal-paste-replacement/
