Budget (including currency):  £800
Country: England
Games, programs or workloads that it will be used for: Warzone, Seige general shooters Microsoft office
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 75+fps. Upgrading from xbox one s
Any recommendations!?!?!
https://linustechtips.com/topic/1367316-please-help/
Country: England
https://uk.pcpartpicker.com/list/ywYX4d
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
https://linustechtips.com/topic/1367316-please-help/#findComment-14947639
Country: England
You can use these specs; the gpu price might be wrong bcs its from my region also the gpu can be swapped for a 1660 super but only if it is at msrp and idk if it would make it overbudget
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (£182.59 @ Overclockers.co.uk)
Motherboard: Gigabyte B450M DS3H V2 Micro ATX AM4 Motherboard  (£62.99 @ Box Limited)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£74.98 @ Amazon UK)
Storage: Western Digital Blue 500 GB M.2-2280 Solid State Drive  (£49.10 @ Amazon UK)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  (£42.99 @ Amazon UK)
Video Card: Sapphire Radeon RX 580 8 GB NITRO+ Video Card  (£214.90)
Case: Fractal Design Focus G Mini MicroATX Mini Tower Case  (£34.99 @ Amazon UK)
Power Supply: Gigabyte P-B 650 W 80+ Bronze Certified ATX Power Supply  (£49.49 @ Amazon UK)
Case Fan: ARCTIC F12 PST 53 CFM 120 mm Fans 5-Pack  (£7.47 @ Overclockers.co.uk)
Total: £719.50
Generated by PCPartPicker 2021-08-23 00:08 BST+0100
https://linustechtips.com/topic/1367316-please-help/#findComment-14947642
Total: £719.50
Don't use those Gigabyte PSU's. Just don't.
I don't know where you imagine he would find that 580 or a 1660S at MSRP to fit into this budget.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1367316-please-help/#findComment-14947647
1 minute ago, PlayerLoler said:
GamersNexus didn't talk anything about the 650w unit only about the 750 and 850w
They might not all explode like the higher-wattage ones but none of them are at all good.
https://linustechtips.com/topic/1367316-please-help/#findComment-14947656
2 minutes ago, PlayerLoler said:
don't you think 480gb might be too small
specially when  the rig is gonna be used for warzone
Well the budget doesn't give me enough headroom for a 512gb ssd
https://linustechtips.com/topic/1367316-please-help/#findComment-14947663
It would hurt loading times but maybe a 1tb hdd can do the job for a while and then later buy a M.2 drive
Nah, instead I would do the other way round, get a 480-500 gb ssd now, so that my boots are fast, and later with some money, buy a bigger hdd storage.
https://linustechtips.com/topic/1367316-please-help/#findComment-14947668
CPU: Intel Core i5-10400F 2.9 GHz 6-Core Processor  (£135.46 @ Scan.co.uk)
Motherboard: MSI B560M PRO Micro ATX LGA1200 Motherboard  (£69.98 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£69.98 @ Scan.co.uk)
Storage: Crucial BX500 480 GB 2.5" Solid State Drive  (£40.14 @ Amazon UK)
Video Card: Gigabyte GeForce RTX 2060 6 GB D6 Rev 2.0 Video Card  (£390.79 @ Overclockers.co.uk)
Case: KOLINK OBSERVATORY LITE MESH RGB ATX Mid Tower Case  (£53.13 @ CCL Computers)
Power Supply: Fractal Design Ion+ 560 W 80+ Platinum Certified Fully Modular ATX Power Supply  (£59.13 @ CCL Computers)
Total: £818.61
Generated by PCPartPicker 2021-08-23 00:36 BST+0100
geometry is hard
b550 > x570
https://linustechtips.com/topic/1367316-please-help/#findComment-14947695
https://uk.pcpartpicker.com/list/kN8ZVc
If you cant get a gpu maybe this is an option
You will want to overclock the igpu to around 2400mhz and for ram youll want to raise the freq till it errors or crashes then start lowering the timings, this will improve igpu performance
https://linustechtips.com/topic/1367316-please-help/#findComment-14947963
Their APGM units are fine IIRC, it's just the PGM that's the problem.
https://linustechtips.com/topic/1367316-please-help/#findComment-14947974
Went with a 240GB SSD paired with a 1TB HDD. Definitely would give you a lot more storage for games like Warzone and other AAA titles.
https://uk.pcpartpicker.com/list/rGK7t8
Motherboard: MSI B460M-A PRO Micro ATX LGA1200 Motherboard  (£68.47 @ Ebuyer)
Storage: Crucial BX500 240 GB 2.5" Solid State Drive  (£27.72 @ Amazon UK)
Storage: Seagate BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive  (£31.00 @ Currys PC World Business)
Video Card: Gigabyte GeForce GTX 1660 6 GB OC Video Card  (£339.99 @ AWD-IT)
Case: Lian Li LANCOOL 205M MicroATX Mid Tower Case  (£51.35 @ CCL Computers)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  (£68.99 @ AWD-IT)
£792.96
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1367316-please-help/#findComment-14947978
Motherboard: MSI B460M PRO-VDH Micro ATX LGA1200 Motherboard  (£69.99 @ CCL Computers)
Storage: Kingston A2000 500 GB M.2-2280 NVME Solid State Drive  (£44.98 @ Amazon UK)
Video Card: EVGA GeForce RTX 2060 6 GB SC GAMING Video Card  (£355.04 @ Infinite Computing)
Case: CiT F3 MicroATX Mini Tower Case  (£25.99 @ AWD-IT)
Total: £803.56
Generated by PCPartPicker 2021-08-23 04:49 BST+0100
https://linustechtips.com/topic/1367316-please-help/#findComment-14948023
