Budget (including currency): €400
Country: Netherlands
Games, programs or workloads that it will be used for: Shadow of the Tomb raider is the heaviest program I'm running
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I'm looking for an upgrade from these components:
Motherboard: Asus P9X79
GPU: Asus Strix GTX 970
CPU: Intel i7-3820
RAM: 4x4 GB DDR3 1600 mHz
No peripherals needed. I play at 1920x1080 at 60 Hz. I wanted an upgrade since my PC is struggling a bit with newer titles such as Shadow of the Tomb Raider.
https://linustechtips.com/topic/1367237-any-help-for-upgrading/
Best I could do with your budget, is this.
https://nl.pcpartpicker.com/list/YY4BCL
If you can save up a little more, I would recommend this instead.
https://nl.pcpartpicker.com/list/Vg7x68
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1367237-any-help-for-upgrading/#findComment-14947133
CPU: Intel i7-3820
All you can do is upgrade the cpu to a 1650 v2, an overclockable 6 core xeon, and yes you will need to overclock it to extract its full potential cause these old cpus dont turbo high
Then i suggest overclocking the sht out of your gtx 970
https://linustechtips.com/topic/1367237-any-help-for-upgrading/#findComment-14947192
PCPartPicker Part List
CPU: Intel Core i5-11400F 2.6 GHz 6-Core Processor  (€220.00 @ Amazon Netherlands)
Motherboard: Gigabyte B560M DS3H Micro ATX LGA1200 Motherboard  (€84.95 @ Megekko)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€76.90 @ Amazon Netherlands)
Total: €381.85
Generated by PCPartPicker 2021-08-22 20:58 CEST+0200
geometry is hard
b550 > x570
https://linustechtips.com/topic/1367237-any-help-for-upgrading/#findComment-14947236
