My current psu fan has started to whine after a bit under a decade of use so figure I should replace it before it dies on me.  Currently running a 5600x on a b550 with a 3060ti FE.  I prefer to stay modular as that's what I have now and hoping to stay under 100 but could push that if need be.  I was thinking something like msi but am open to suggestions.
 https://www.amazon.com/gp/aw/d/B08PDV45F8/ref=ox_sc_act_image_1?smid=ATVPDKIKX0DER&psc=1
https://linustechtips.com/topic/1366876-need-replacement-psu-advice/
The price is right and the product isn't terrible i mean you do you in the end. Surely their is some other reccomendations but that isn't a bad one to begin with I would just go with that one and not overcomplicate it 🙂 seems fine to me! Budget is a Budget.
Ryzen 9 7950X 5.9 GHz 16-Core, Full Liquid CoolingROG Crosshair X670E EXTREMEG.Skill Trident Z5 6000 MHz 64 GB, EVGA GeForce RTX 3080 Ti FTW3 Ultra 12 GBSeasonic PRIME Platinum 1000WKingston HyperX Cloud II 7.1 Channel, S.S Arctis 5 7.1Roccat Kain 200 AIMOLogitech G403 HeroASUS TUF VG27WQ 1440P 165 HzASUS VG34VQL1B 34" 1440P Ultrawide 165 HzCrucial P1 1 TB M.2-2280 NVME 2xSamsung 870 QVO 4 TB 2.5" SSDFractal Design Meshify 2 XL Case
You are probably right lol.  I just overthink when it comes to this type of thing.
It's OK i do too .. I replaced my case 4 times within 2 months.. Eh .. just go with your gut you aren't making an awful choice here seems fine to me.
