Budget (including currency): its free
Country: USA
Games, programs or workloads that it will be used for: steam games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):   so my uncle has a power supply but i don't know if the cables are the same on all power supply so tell me if you can change your power supply out without needing new cables. and if so how can i tell what socket is on my power thingy so i can test thing out
https://linustechtips.com/topic/1366293-changing-power-supply/
Country: USA
You can't swap cables between power supplies, they are not guaranteed to be compatible, and might damage and destroy your components
https://linustechtips.com/topic/1366293-changing-power-supply/#findComment-14940009
Don't cross cables between power supplies. If it's a (semi-)modular power supply and he doesn't have the cables, then you'll either have to source the cables that came with that power supply or else you're SOL.
It's entirely possible that I misinterpreted/misread your topic and/or question. This happens more often than I care to admit. Apologies in advance.
珠江 (Pearl River): CPU: Intel i7-12700K (8p4e/20t); Motherboard: ASUS TUF Gaming Plus Z690 WiFi; RAM: G.Skill TridentZ RGB 32GB (2x16GB) DDR4 @3200MHz CL16; Cooling Solution: NZXT Kraken Z53 240mm AIO, w/ 2x Lian Li ST120 RGB Fans; GPU: EVGA Nvidia GeForce RTX 3080 10GB FTW3 Ultra; Storage: Samsung 980 Pro, 1TB; Samsung 970 EVO, 1TB; Crucial MX500, 2TB; PSU: Corsair RM850x; Case: Lian Li Lancool II Mesh RGB, Black; Display(s): Primary: ASUS ROG Swift PG279QM (1440p 27" 240 Hz); Secondary: Acer Predator XB1 XB241H bmipr (1080p 24" 144 Hz, 165 Hz OC); Case Fans: 1x Lian Li ST120 RGB Fan, 3x stock RGB fans; Capture Card: Elgato HD60 Pro
翻生 (Resurrection): CPU: 2x Intel Xeon E5-2620 v2; Motherboard: ASUS Z9PR-D12 (C602 chipset) SSI-EEB; RAM: Crucial 32GB (8x4GB) DDR3 ECC RAM; Cooling Solution: 2x Cooler Master Hyper 212 EVO; GPU: ASRock Intel ARC A380 Challenger ITX; StorageCrucial MX500, 500GB; PSU: Super Flower Leadex III 750W; Case: Phanteks Enthoo Pro; Expansion Card: TP-Link Archer T4E AC1200 PCIe Wi-Fi Adapter Display(s): Dell P2214HB (1080p 22" 60 Hz)
壯麗 (Glorious): Mainboard: Framework Mainboard w/ Intel Core i5-1135G7; RAM: G.Skill Ripjaws 32GB (2x16GB) DDR4 SODIMM @3200MHz CL22; eGPU: Razer Core X eGPU Enclosure w/ (between GPUs at the moment); Storage: Samsung 970 EVO Plus, 1TB; Display(s): Internal Display: Framework Display; External Display: Acer (unknown model) (1080p, 21" 75 Hz)
https://linustechtips.com/topic/1366293-changing-power-supply/#findComment-14940030
@CostinNathan I have merged your 2 threads. Please keep to a single thread for the same issue/question.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1366293-changing-power-supply/#findComment-14940038
21 hours ago, CostinNathan said:
You'll need to source the cables from the manufacturer, or from a place like Cablemod (idk if there are any other vendors that do stuff like that for cheaper) where they ask you the exact model of the PSU.
https://linustechtips.com/topic/1366293-changing-power-supply/#findComment-14941826
