Can I run a 1080p high refresh rate monitor using hdmi 2.0?
PlayerLoler
Im looking to buy a high refresh rate ( around 144-165 hz)  1080p monitor but my pc only has an hdmi 2.0 port, I though about using a hdmi to dp adapter but I think it wouldn't work so can anyone tell me if this is possible or not?
Yes if both components (GPU and Monitor) support it.
What GPU do you even have considering it only has hdmi?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
A modern monitor with an HDMI port of that kind would be able to do high refresh rate. My girlfriend is using the Prime X570-P which only has HDMI 1.4b and it still offers 144Hz
Primary PC:
a rtx2060
Ok thanks a lot for the help
38 minutes ago, PlayerLoler said:
a rtx2060
Are you sure it has no displayport? It's better and most monitors come with a cable for it. If you want some advice for a good monitor I recommend an AOC C24G2.
It doesen't have displayport since its a laptop and im considering ACER KG241QS or Ozone DSP25
